08-01-2013 07:49 AM
@JÞB wrote:
@Thoric wrote:
@JeffMotes wrote:
Yes
Bimey. I didn't know that was possible. Deploying to FPGA from Windows, via a LabVIEW dll. Sorry, but that's not something I feel I can help with anymore. Maybe a blue member can jump in here and assist?
That certainly sounds possible! Calling a dll created from a LabVIEW build to export a LabVIEW wrapper to lvanlys.dll from LabWindows SHOULD work (albiet, its a rather "round about" way to get to a solution.... seriously! call the lvanlys.dll function directly)
What may not be possible is the floating point math operations being targeted to a FPGA! What lead you down this "long strange trip?"
SpoilerI can use that quote from Jerry Garcia, I'm from Minnesota too!
Jeff, the calling of Integral from a dll is certainly possible, it's the FPGA deployment that's got me wondering. How would a LabVIEW dll, in Windows, deploy FPGA code?
08-01-2013 08:00 AM
I'm not exactly sure what you mean by deploy but the FPGA portion is not my problem. I have been doing what I need there for a while now. My only problem is using the PtbyPt Integral function in a LabView VI and calling it from LabWindows. With the Integral function in the VI, the call from LabWindows hangs execution. I can remove the function and rebuild and LabWindows does not hang.
I have a LabView Project that contains FPGA VIs. Within that project, I have other LabView VIs for downloading and running the FPGA VI code. It is the download, run, etc VIs that I complile into a DLL that is executed from LabWindows. I hope that explains my situation a little better.
