Insufficient Transfer Engine Resources
I have an app with 2 (eventually 3) AVT Pike 100C cameras and Vista with LV 8.6.  I am getting the Insufficient Transfer Engine error when I call Configure Acquisition on the second camera.
I have reviewed and tried the solutions in this thread, but I still get the error:
http://forums.ni.com/ni/board/message?board.id=200&thread.id=12460&view=by_date_ascending&page=1
Some notes:
These cameras have a FIFO, and I am using that to capture just a few images in a deferred image transfer mode.  So throughput is not important.
I have set each camera's bus speed to 400Mbps.  I have set each packet size to 1024 bytes.  The cameras are  daisy-chained on the only 1394 bus I have on this laptop
I have set the bus parameters both through the IMADdx driver, via MAX and by setting registers.  Each method appears to affect the others (that is, I can set the packet size via the enumerated interface, and see the result by reading the appropriate register on the camera).
(2,458 Views)
Accepted by topic author Jed_Davidow
Whoops.  Thought I had posted this to machine Vision.
Reposted there:
http://forums.ni.com/ni/board/message?board.id=200&thread.id=21054
(2,437 Views)
By the way, when you insert your image, don't get the source from the preview of your message.  It doesn't work because the preview is a temporary location.  You have to submit the message with the attachments included.  That gives you the permanent web server location and message ID.  Then you can edit the message and insert the images based on their location on the webserver.
(2,423 Views)
