09-14-2016 12:08 AM
Hi
Can I interface a micropipette with PC by using LabVIEW DAQ module? That kind of micropipettes (electrically operated) available in the market?
Solved! Go to Solution.
09-14-2016 01:47 AM
Hi arunamv,
which "kind of micropipettes" are you talking about? Any specific type/producer. any manual you can link to?
Generic answer to your generic question:
When the interfaces of your pipette and the DAQ device fit you can surely control the device from your PC…
Hint:
Usually you have some hardware with a certain interface (with mechanical, electrical and protocol specifications). Then you select DAQ hardware (or interface connectors/converters), which is able to connect to your hardware (again checking all the required specs).
If you would supply your requirements we could recommend DAQ devices…
09-14-2016 01:51 AM
I need to know about electrically actuated micropipettes or fully automatic micropipette.
09-14-2016 01:55 AM
micropipette available in net is 1) micropipettes with plunger mechanism and the other is 2) with a chargable battery, digital display with different switches. I need completely automatic, ie electrically operated like on off solenoid valve
09-14-2016 02:42 AM - edited 09-14-2016 02:42 AM
09-14-2016 02:45 AM
My question is that kind of pipitte is available or not and i want to interface it to pc by using labview..
09-14-2016 02:48 AM
