04-28-2015 12:45 PM - edited 04-28-2015 12:49 PM
Hei,
My goal is to establish USB bulk communication between an USBdevice and Labview. I have been following this procedure: http://www.ni.com/tutorial/4478/en/ and used NI-VIsa Driver Wizard.
Everything went fine till I have to create cat file. This I have to do because my OS is 8 and in oder to get "allowance" to install the drivers I need to have it digitally signed. Appereantly it should be at location:
C:\Program Files (x86)\Windows Kits\8.0\bin\x86
But I can't find the in2cat exe nowwhere. I reinstalled the the windows kit where the inf2cat appereatly is couple of times. So,
How do I get to inf2cat?
Is there any other "cosy "way to establish USB communication?
Any recommendations or advices are also appreciate.
thanks for the help
Solved! Go to Solution.
04-28-2015 01:46 PM
04-28-2015 04:00 PM
It is just a simple microcontroller that ia already programed and the only way to acces it, is through usb. Also everything is provided VID-PID, endpoints with pipes, command syntax... to establish the protocol. Other protocols I2C and SPI are not document. So, that's why I thought to use NI-VISA driver wizard 🙂
05-05-2015 03:14 AM
Does it work if you try to disable the "Safe Drivers" setting in 8?
http://www.makeuseof.com/tag/how-can-i-install-hardware-with-unsigned-drivers-in-windows-8/
05-07-2015 07:59 AM
Simon, thanks a ton. You are a life saver 🙂
