11-17-2015 02:16 PM
I am having an issue where one of the directories associated with the build that this installer is supposed to install, is not being included.
In this screenshot, I have a red arrow pointing to the only folder that's missing in C:\Test System Software\<appName>\
here's an imgur link: https://imgur.com/pOLF9mC
I have rebuilt the exe and it reproduces the missing folder and rebuilt the installer after the exe and it's still missing from it's installed directory.
Using LV 13.0 32b
11-18-2015 10:54 AM
Making sure the question is understood:
When you run the installer for a build, the "SHUTDOWN" folder is missing from the application. You want to know why this is happening?
Can you clarify what you mean by "rebuilt the exe and it reproduces the missing folder"?
11-18-2015 11:07 AM
"SHUTDOWN" dir is missing from exe's root/base directory after installer runs, but is correctly created and populated by the exe build process.
I'm just stating that I made sure this is an issue of the installer and not the exe build.
thanks
-pat
11-18-2015 11:46 AM
Is the folder empty? Are any of the other folders that you include empty? I think it's possible that the installer might skip empty folders - I think I might have run into this or a similar issue before? I think in that case I put a dummy file inside the folder and in future applications, I usually create the directories in my application if they don't exist.
11-18-2015 11:47 AM
The shutdown folder has some batch files in it for shutdown and restart execution, and the exe build does populate as expected.
thanks
-pat
11-18-2015 11:54 AM
What settings do you have on the Destinations and Source File Settings page?
11-18-2015 01:25 PM
see here: http://imgur.com/OBWNy1A
I actually just noticed that the checkmark for default install is still on program files, however it does install the exe and everything BUT the shutdown folder in the dir I made down in Test System Software
Thanks for the help... and also, cool avatar, is that some kind of dna/genetic ID info I see there?
-pat
11-19-2015 03:26 AM
Have you sorted it then? It wasn't clear from the post.
Yeah - I had a DNA print (you send them a swab of your cheek and they send you a canvas print) done a few years ago - can't get much more of a personal avatar than my own DNA!
11-19-2015 07:19 AM
I selected the directory I wanted everything to install into and out the red checkmark on it... it WORKED.
still surprised that only one dir was left out, and eveything else ended up there where I wanted it...
Thanks!
-pat
