03-08-2010 10:27 AM
Hi All.
I was trying to install LabVIEW 7.1 into my laptop.
However, the same message was appeared during the installation.
And I also tried to install with LabVIEW 8.6, but still the same problem occured.
The error message as below:
The NI LabVIEW 8.6 installation has failed with the following error.
Error 1402. Could not open key : HKEY_LOCAL_MACHIENE\SOFTWARE\Classes\LVDB.Application\CLSID.
Verify that you have sufficient access to that key, or contact your support personel.
Continue?
If anyone having the solution of this problem, kindly let me know!
Thanks a lot.
- Fird
Solved! Go to Solution.
03-08-2010 11:32 AM
Check here:
http://forums.ni.com/ni/board/message?board.id=170&message.id=148774
03-09-2010 07:56 AM
These problems solved already.
However, I have another problem now.
The message appear as attachment when I was trying to install LabVIEW 8.6
I'm now using Windows 7.
- Fird
03-09-2010 08:44 AM
This question has come up several times already in the forums. Try searching for Error 12 and Windows 7.
Here is one thread discussing it. http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=452641#M452641
