05-01-2014 07:30 AM - edited 05-01-2014 07:35 AM
I am working on a project using LabView.
I installed it few months ago and it installed normally.
After that, I had to uninstall it.
Now when I reinstalled it again, it gives a message about installing NI drivers.
I am attaching a screenhot.
labVIEW is asking for additional drivers for it's installation.This did not happen before.
Please Help.
05-01-2014 07:41 AM
05-01-2014 07:44 AM
I would not have asked this question then.
It asks for "additional drivers" (clearly written in the question).
I already installed the drivers I had. Do you have something useful to offer?
05-01-2014 08:00 AM
Check in your project, are you using DAQmx drivers or not. If not you dont need to install any.
05-01-2014 08:02 AM
05-01-2014 08:04 AM
I uninstalled it few months ago.
Now I have reinstalled everything again(including the drivers)
05-01-2014 08:07 AM
05-01-2014 10:35 AM - edited 05-01-2014 10:36 AM
When installing LabVIEW, you need to install the drivers. If the drivers are already installed, then you still need to install the "LabVIEW 2010 Support" for the drivers (part of the driver installation). This is quite normal.
12-13-2018 03:31 AM
Have your problem solved ? i have the same problem exactly like you also. Please help me thanks !
