Inner Join for 2D Arrays
Hi all.
I have 2 sets of data that we need the difference of.
However both sets might have erronous duplicate readings that cause either one or both of them to be of UNEQUAL length.
Data is 2D with the column 0 being timestamps and column 1 being a physical number.
I need the timestamp column to correspond for both arrays, at the same time making them the same length.
I believe the following method is somewhat similar to the INNER JOIN function that SQL Databases use.
Example:
Timestamps will be shown as TX.
Set A (size of 😎
T1   0.1
T2   0.1
T2   0.1
T3   0.2
T4   0.1
T5   0.3
T5   0.3
T6   0.2
Set B (size of 6)
T1   0.9
T2   0.8
T3   0.7
T5   0.9
T6   0.9
T7   0.8
From the above 2 sets, either set can have missing or duplicate data. The corrected array should look like:
Set A (corrected size of 9)
T1   0.1
T2   0.1
T2   0.1
T3   0.2
T4   0.1
T5   0.3
T5   0.3
T6   0.2
T7   NaN <--- added from B's T7
Set B (corrected size of 9)
T1   0.9
T2   0.8
T2   NaN <--- added from A's additional T2
T3   0.7
T4   NaN <--- added from A's additional T4
T5   0.9
T5   NaN <--- added from A's additional T5
T6   0.9
T7   0.8
Sorry for being long-winded but I couldnt see any other way to explain it.
Help would be appreciated.
Thanks.
(2,582 Views)
You'll need to loop through Set A's TX and do a Search Array against Set B's TX. If Search gives -1, it isn't found and you should add it to Set B. Then do the same in the opposite way.
Since TX is the 1st element you can just do a Sort afterwards.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,507 Views)
