06-27-2017 02:12 AM
Hi everyone
I am new to labview. Currently I am working on accuring analog input and generating output using DAQ assistant by interfacing it with NI PXIe-1082.
I want to know that in DAQ assistant what does it mean by Acquisition mode. There are 4 of them
1) 1 Sample (on demand)
2) 1 sample (HW timed)
3)N samples
4) continuous samples
I also wanted to learn about NI 6363 card. Please mention any link of study material available regarding NI 6363 card.
Thank You
06-27-2017 02:44 AM
Hi aviralp,
10 DAQmx functions you need to know
NI6363: NI offers lots of documentation for all its hardware, so why don't you read it?
06-27-2017 02:51 AM
Quick description of the behaviour of each of those:
1- A single sample is taken when the DAQ Assistant function is called in your code (if it's in a loop it will generate 1 sample each iteration)
2 - A single sample is taken, but this is controlled by the hardware clock. Some hardware require this to be the method instead of the On Demand method.
3 - This will generate the number of samples specified when the function is called. If this is in a loop it will generate the same number of samples each time.
4 - This is used to continuously run acquisition or generation.
Hope this helps.
Nic
