08-11-2015 11:15 AM
08-11-2015 03:08 PM
You haven't supplied enough information here for us to help you. Do you have a specific motor you are trying to control? If you have a device that can communicate with LabVIEW, there are a set of commands (or rules) that the communication needs to follow. If your device comes with a command list, then you can use these commands to control it with LabVIEW. What kind of communication does your device utilize? USB? RS232? RS485? TCP/IP?
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
08-11-2015 03:16 PM
08-11-2015 03:19 PM
Still not enough information... How do you expect to communicate with the motor to control it?
Cheers
