Indicator as control (iterationio counter as index number)
It depends on what the heck this routine is supposed to do?  You keep changing the inputs and outputs of the routine so there are different solutions.  My impression was that you wanted to test each byte of the array.  If you want the bytes to be separate this would do it.  If you want them in an array it isn't.
You can simplify it by pulling down on the index array and creating 8 index inputs.  You only need to wire the top one.
LabVIEW ChampionLabVIEW Channel Wires
Message 11 of 20
(576 Views)
You don't even need to wire the top index since it defaults to 0.
Message 12 of 20
(575 Views)
One step at a time....  🙂
Message 13 of 20
(562 Views)
Hi there,
For me as a totally fresh guy it is quie hard to imagine about what exaclu you talking, so is it possible that some of you will your idea in block diagram?
Message 14 of 20
(540 Views)
Exactly.  You need to review the basics so that you can understand the help.  Spend some time with the tutorials.
Here are the two versions we were talking about.  The top splits the array into 8 outputs that are elements.  The bottom does an iteration and can process each byte of the array.
Message 15 of 20
(527 Views)
sth,
Your picture failed.  I don't know how you tried to include it.  Be sure to attach it to your message, then edit your message and use the 3rd optioni on the Embed Picture dialog to inser the picture based on "3rd party" website which is the properties of the recently attached file.
Message 16 of 20
(518 Views)
sth could you add that picture correctly so i can see it?
Message 17 of 20
(505 Views)
I just pasted it into the message.  All that great Lithium software shows it fine in my message.  Like this.
However the problem is that LV puts any cut and paste on the clipboard as a TIFF which seems to work in edit mode but not when I post it.   So here it is as a JPEG.
Message 18 of 20
(497 Views)
Both images show for me just fine.  Still problems?
Message 19 of 20
(496 Views)
No, it doesn't show up.
Are you using the embed picture button on the editor toolbar?
What browser are you using?
The properties of the image are "webkit-fake-url://AC1C7D53-13A3-4B45-B74F-D7A1BB425B15/image.tiff"
I have no idea what a webkit-fake-url is supposed to be.
Just attach your image as a file to your message.
You can't "just paste" an image into the editor.  You can probably see it because the image is cached on your PC.
Message 20 of 20
(492 Views)
