Hi, I am stuck trying to increment a value based on an event within a while loop. Whenever the mouse is clicked, the value should increment by one. I am using LabVIEW 7.1 and any suggestions is greatly appreciated.
Use a while loop and keep the current counter in a shift register. Inside the loop, use the mouse-down event to increment the counter. See attached simple VI example.
