03-18-2008 04:36 PM
03-19-2008 01:49 AM
Thanks for your answer 🙂
But then I don't understand workaround #2 (described a few replies before from Juan Galindo):
"2. Place the stacked plot in another VI and show it on the front panel via a sub-panel. Then use VI server to programmatically update the chart."
So there's no workaround, or?
Or have I done something wrong in my VIs?
Yes, you're right, I can update the values in the "test chart.vi" using VI server set property but I still cannot change the number of stacked plots, or?
Best regards
Hans
03-20-2008 10:46 AM
03-25-2008 04:05 AM
In the examples and descriptions (of using VI server) I've found, only values of controls of the opened VI are changed, but no property node like "LegNumRows" property node of the Chart !
So I don't know how I should change my VIs to set the "LegNumRows" property node of the Chart in the "test chart.vi" with VI server 😞
Can you please modify my VIs the right way or can you give me a hint?
Best regards
Hans
03-26-2008 04:07 PM
03-28-2008 02:11 AM
03-28-2008 03:12 PM
03-30-2008 08:17 PM
03-31-2008 01:56 PM
04-14-2008 01:40 PM
According to the 8.5.1 bug fixes at http://zone.ni.com/devzone/cda/tut/p/id/6927, this is reported to be fixed. "Fixed Issue > Front Panel"
4CUGA5RK |
Resizing stacked plot chart legend at run-time crashes LabVIEW |
but my example vi in the first post now gives an error even when decreasing the number of legend rows.
Error # 1000 "This vi is not in a state compatible with this operation" at the Legend : Number of Rows property.
The original 8.5 Known Issue is at http://zone.ni.com/devzone/cda/tut/p/id/6449#4CUGA5RK
Steve
