Include constant in Array
Hello All,
Using the ramp function i have generated an arry of Values from my min, max and the step. Now i want to add another array with 2 constants alternately along with this array. Such that if i have 10 values in this array then the constants should be inserted only 10 times alternately and if this array has 100 values then accordingly. A short example is shown in the attachment!
Regards!
(2,902 Views)
I am not sure I understand your goal here.  Perhaps an example of data would help (what you have coming in and what you expect as a result).
GCentral
(2,880 Views)
Accepted by topic author acuteboy
This should do what your example shows.  I'm sure there is a more elegant solution than this but it's what I got.
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
(2,874 Views)
I want an array in this format (see picture). The first column can be created using the ramp funtion as shown above with the help of Min, Max and step values as inputs. I want to include the second column where i can insert two constant values alternatively.
(2,873 Views)
Actually you can get rid of the transpose by moving the "Build Array" inside the while loop and wire it up with the input array.
aputman
(2,865 Views)
another approach:
(2,857 Views)
