In range and coerce with complex numbers?
I have an array of complex numbers with these numbers I need to set to 0 all numbers whose real parts are negative. With "in range and coerce" I can split the array into real and imaginary then set all negative numbers to 0 then recombine the complex part but that still leaves me with 0+ai numbers that should be 0. How can I also set the complex part to zero for the negative numbers?
(2,952 Views)
You can use the following fonction in a for loop with your array.
Michel
(2,937 Views)
Ben64
(2,931 Views)
How would I arrange the two for loops to iterate over a 2d array? Sorry I'm quite new to labview.
(2,929 Views)
You should go through a basic tutorial, you will find plenty of them on NI website.
(2,923 Views)
You really don't need any loops.  Many LV functions that work on scalars also work on arrays.
(2,885 Views)
