In Place Element Structure or not??
Hi!
I have an array of a cluster. I want to increase a field called "Counter" for each array item and thought of three ways to do it (Solution A, B, and C in the picture).
Is there a difference between the solutions? At what "dimension size" does this difference become important? Or is it at what interval I call this function that it becomes important?
Is there a forth and better way to do this?
Thanks in advance!
BD
(2,819 Views)
There shouldn't be any difference between these solutions. I'd stick with the simplest one. The compiler will recognize that the unbundle/increment/bundle operation should happen in-place (this is a"magic pattern" that the compiler can identify) so no need for the in-place element structure.
(2,799 Views)
If the cluster if big i'd use #1, else #3. You can easily setup a timer to see how long it takes.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,787 Views)
A 4th solution is to mix B and C and user the ordinary cluster function inside the array in place.
/Y
Qestit Systems
(2,784 Views)
