02-18-2013 06:35 AM
Greetings,
I want to make an application that writes measured values to a .tdms file.
But I want to make a seperate database in a .tdms file which contains the theoretical values.
After the measuring the application should compare the measured values with the theoretical.
So the application should read just one cell of the .tdms file.
Is this possible?
02-18-2013 07:40 AM - edited 02-18-2013 07:46 AM
Yes
Have ou had a look at the examples that come with LabVIEW? There are several examples about how to use TDMS files.
Help >> Find examples... >> type "TDMS" in the Search tab.
Epictetus
02-18-2013 07:11 PM
Here are some materials:
http://www.ni.com/white-paper/3727/en
http://www.ni.com/white-paper/5696/en
I also recommand you can start with the TDMS examples in LV to get familiar.
