Implementing serial communication to the existing parallel communication
Hi all,
Currently I am doing a project to create a portable yet inexpensive energy meter.
The main hardwares that I am using are ADE7753 as the energy IC, and Rogowski coil as the current sensor.
Right now, the ADE7753 sends the data to PC through parallel communication.
Therefore, I would like to implement the serial communication to the existing parallel communication as next step.
However, I found it is very difficult to begin the programming part. The labview program that I have is a modified version. The original one was received from Analog Devices.
Hopefully, you guys can help me with this matter.
Here I have attached the file
Thank you
(2,501 Views)
if I'm not mistaken you just want to use a serial communication (VISA)?
This document maybe gives you a good way to start...
Good luck
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(2,496 Views)
Hi ABCPrograms,
First of all, thank you for your response 🙂
Sorry for not really focuing on my problem. Previously, I also have a problem in connecting to serial, however, I have solved it.
Now actually, I have a problem of VI in which it can retrieve data from USB or parallel communication. However, I need to use serial communication to retrieve the data.
I wonder how to do it in serial communication.
Here I attach how USB and parallel communication retrieve the data. Feel free to look at it.
I really thank you and appreciate your help in this matter.
(2,441 Views)
mmm, I can't seem to figure out how your program works, but I bet it's just me 😉
This is how you could write a serial communication (even better to put it in a state engine and a functional global for the data)
If you need to send commands before a reply then you can add that by your self
Serial
Kind regards,
- Bjorn -
(2,424 Views)
