01-28-2006 01:28 AM
01-28-2006 02:04 AM
01-30-2006 11:44 AM
01-30-2006 01:38 PM
01-30-2006 02:26 PM
Hi xseadog,
1. Could you point out where you found that default 13 address? I think I saw it but could not find...
2. If I push "run continuously" button, I can see that the instrument shows freq of 33MHz and the pulse width/duty cycle is calculated based on this freq. I think there must be some 33MHz set as a default in one of the setting, but cannot find where this is happening....(for EXT trigger case)
3. This may be due to the insufficient wait states???
BR,
01-30-2006 03:50 PM
01-30-2006 04:22 PM
02-01-2006 07:00 AM
02-01-2006 09:57 AM
Hi xseadog,
I asked this question before, but I could not find where that default 13 address is occuring in initialize vi. I checked the properties of all the subVIs, but could not find.
Again, when the instrument is EXT trig'd, width is calculated from freq of 33MHz (which is not the ext freq), then when VI stops, the freq on the 8133 switches to ext freq, but not the pulse width setting???
Could you help how I can fix??
BTW, I looked the VI that I had uploaded, so I think we are looking at the same file.
02-01-2006 04:21 PM
