Hi Jjlee
if you read page 164 of manual you wil see that one can query the instrument settings with the following
command:
SYS:SET
You may have to add question mark at the end. Suggest you use NI spy at
same time so you can see what happens. Note that the actualdata block
is binary format not ascii.
The actual instrument has 20 memory 'registers' so you could actually manually set up instrument for the different
test to be performed.Then you just have one vi block to content with -Recal memory X-then system ready to perform.
Advantage is that it saves coding! but it is essential that settings are noted in case the memory is corrupted or overwritten
by accident. I prefer to use this solution if there is a comptent operator running the system. Set ups are noted
and are availble for amendment.
However due toa vunerabilty, QA departments do not like this method as open to undocumented modification.
With regard to Saving FP settings, all that you need to do if run your
appropiate VI (if it is working correctly)then under operate menu
Make current settings default. save vi as another name ie 'present FP setting.vi'.
I'llcheck out the NI spy data
Chow
xseadog
