01-23-2006 02:44 PM
01-24-2006 08:50 AM
Hi xseadog,
Thanks for your helpful comments!
I will try your suggestion.
1. I did not quite understand your point 1 about 4 inputs/4 outputs. Are you talking about 'readkeyandbuildcluster_mod.vi' (?) Could you please provide some more details? How can I do this? Just change the terminal config?
2. How can I do the following?
On the program boot-up;
#1. frontpanel interface VI 'Query' and synchs up with the 'turn-on' settings of all instruments and prompt a user to load (existing) config file. Do I have to make another case for query or can I combine this with load config?
#2. How can I remove the reset commands for re-initializing instruments with default setting? (Perhaps, both of above questions are closely related?)
The bottom line is;
-to query initial instrument settings and update frontpanel (and then)
- to prompt a user to load config file
Could you plz help? I really hope to get this working before I move onto other part of this program....thanks in advance!
sincerely,
01-24-2006 04:19 PM
01-25-2006 01:30 AM
01-25-2006 10:41 AM
01-25-2006 03:47 PM
01-25-2006 04:04 PM
01-25-2006 04:19 PM
01-26-2006 01:14 AM
01-26-2006 09:55 AM
