01-19-2006 03:20 PM
01-19-2006 03:44 PM
01-19-2006 04:49 PM
Please let me attach a library file with all the subVIs.
1. Using "Load Config" button, I can load different parameters on "Aggressor Settings" tab. However, this does not change the actual instruments settings with a loaded Aggressor Settings.
2. Aggressors are just my way of calling "HP8133A" pulse gens.
Could you guide me to how I can resize the VI, so that it can fit within the size of a monitor?
3. Please let me attach this block diagram to help you understand what I am trying to do.
Best,
01-20-2006 10:24 AM
I guess it is not so clear to me that I can only load instrument settings on the front panel with a text file and instruments will click and change once "Run Test" button is pressed(?)
Is there a such thing as instant physical clicking of an instrument as soon as a text file is loaded onto the front panel interface???
I may not be asking something impossible....
01-20-2006 11:24 AM
01-20-2006 03:57 PM
I do agree with your rationale, but my boss was thinking otherwise. I did not get this point, but I am trying to find out if it is even possible.
Could you please comment on some of my problems with the VI?
1. Loading configuration file
It reads okay, but does not write correctly on the instruments. what can possibly go wrong? For example, I specify a duty cycle of 25% and once the "Run Test" button is pressed, Aggressor5 displays some hug duty cycle value? I even reset all the instruments, but still no idea why...
2. No waveform & text file content
- It looks to me that 'crosstalk measurement' block in "run" case is working okay. Why there is no waveform in the near end crosstalk plot?
- Could not find any x,y data in the text file except some header info....how can I fix this?
Thanks always for your great advices!
01-20-2006 04:06 PM
01-20-2006 04:25 PM
01-23-2006 11:21 AM
01-23-2006 01:54 PM - edited 01-23-2006 01:54 PM
Message Edited by xseadog on 01-23-2006 01:55 PM
