08-12-2014 11:55 PM
Hey guys,
I'm writing a VI for my Smart Camera. I'm trying to use ImaqWriteFile2.vi, and I'm having some trouble with the file path. I understand that because I'm running the code on my Smart Camera, the file path specified will be on the camera itself rather than my dev pc, so a file path like C:\Users\Blah\... will not work. My question is, the camera is connected to my dev pc via ethernet, so what address do I put to save the image on my desktop, for example? Apologies if the answer to my question can easily be found somewhere other than this forum, but my google-based research has not been fruitfull.
08-13-2014 12:04 AM
Do you have a directory shared on your PC? If so, I'd try the network path to that directory such as \\MyPCName\c\DirIShared
08-13-2014 12:30 AM
Thanks for the reply. I just tried that, and it doesn't seem to work.
08-13-2014 01:29 PM
Hi mprevodnik,
You may be able to set up your PC as an FTP server and just FTP it over ethernet. Here is resource on how to do so with a Windows XP machine, but you can just adjust it for Windows 7.
08-13-2014 07:56 PM
Thanks for the reply. I don't have Vision Builder VI, so I can't complete step 10. I tried to run my VI anyway and it still isn't writing any files, despite not receiving any errors.
08-14-2014 11:12 AM
Hi mprevodnik,
You might want to look at using FTP in order to transfer information from the RT to your host:
https://decibel.ni.com/content/docs/DOC-15379
