11-14-2008 07:44 AM
11-14-2008 09:01 AM
With so little information, it's hard to help. What kind of sensor, voltage range of analog signals, how fast do you need to convert, how many bits of resolution?
Almost sounds better suited to a pure hardware approach instead of LabVIEW.
-AK2DM
11-14-2008 11:53 AM
11-17-2008 05:16 AM
Hi, Thank you for using the forum.
To help me understand the issue, could you expain your application, what you are using and what are the parametres set for?
Also what kind of images you wish to aquire?
Regards
11-17-2008 08:02 AM
just a normal imge i suppose using the CMOS aps.. i havent gotten the CMOS aps yet...im still learning on how to use labview...
Since the image captured by the cmos aps are stored as voltages in CMOS aps.. i tihnk what im supposed to do is to acquire all these signals and convert them into digital signals or something... well at this stage what i want to know is how could i access the arrays using labview...to analyze the voltages....and how can i store these voltages as well...and also i have only 1 analogue input..
