09-04-2012 05:48 AM
How to scale image independently for Height and Width using labview 8.5 software. Zoom factor is scaling 1:1. need to change the aspect ratio.. in my case need to change the width of the JPG image..
09-04-2012 05:59 AM
Hi Hari,
You can use word Format picture VI
09-04-2012 06:07 AM
This knowledge base article may help
http://digital.ni.com/public.nsf/allkb/09F6A234EBFCDC7786256DDD0056668F
09-04-2012 06:18 AM - edited 09-04-2012 06:23 AM
@ danil33..word format picture is not available in the reports pallete..it is available in "Report Generation Toolkit for Microsoft Office " which has to be purchased are there any other vi's available..
@ Frabto..the second suggestion also scales with 1:1 ratio..
Thanks for your suggestions..
09-04-2012 06:58 AM
Hi Hari,
Have you tried this:-
http://zone.ni.com/devzone/cda/epd/p/id/2201
09-04-2012 07:06 AM
Yes,, I tried that earlier.. it too scales 1:1..
09-04-2012 07:24 AM
So what about zoom factor property ?
09-04-2012 07:48 AM
all the above examples use Zoom factor property..
09-04-2012 12:21 PM
It would require installing ImageMagick, but there is a LVOOP based library on the LAVA forums that can be used to manipulate images from within LabVIEW.
http://lavag.org/files/file/48-lvoop-imagemagick-interface/
http://www.imagemagick.org/script/index.php
