03-03-2015 12:53 PM
Hello!.
03-04-2015 01:58 PM
You should be able to use the Zoom Attribute.vi built-in example and alter it for your needs. You can find this VI in by opening LabVIEW, clicking Help->Find Examples...->Click the search tab->Search for "zoom attribute"
Double click on the VI and test it to see how it zooms and pans an image.
03-04-2015 02:50 PM - edited 03-04-2015 02:57 PM
Daniel ,thanks for the reply but may problem is that the when make zoom in the back picture the above plot zoom no change. I will make to copy programatically the zoom picture in the XYGRAPH zoom. But the zoom in the GRAPHXY (i belive) is maked only whith the graphpalette. This is the real problem
Thank for the help, sorry by my bad English!.
03-05-2015 01:53 PM
The NI Vision software contains several of the palettes you're talking about. It is a separate software package that you can view here.
