05-30-2007 07:47 AM
05-30-2007 12:03 PM
Only idea I have: Try to change a property that you cannot change for a strict typedef. If you get an error, it is a strict typedef. If it is not, you can change the property's value back to the value it had before the change.
I think that no common property exists that you can use for this. This prevents you from doing it the generic way.
Does anyone have a better idea?
Regards, Guenter
05-30-2007 02:09 PM
05-30-2007 11:55 PM
Thank you both for your help. My next question in the same line is
Can we dynamically open a strict typedef cluster and save it to typedef
cluster?
05-31-2007 05:28 PM
06-05-2007 07:31 AM
06-05-2007 08:08 AM
Nick,
Is it a Private property, I mean, NOT available in LV 7.1 ?
Please clarify me...
