Icon Editor Crash
I am using LabVIEW 2015 64-bit. Everytime I double click an icon to edit it the icon editor flashes for a moment, then seems to crash, and is replaced by the old icon editor from years ago. Everything else seems to be working fine.
I updated my version of LabVIEW yesterday to see if that fixed it, but it still happens.
Does anyone know why the icon editor doesn't work, or how I can get it to work?
Message 1 of 11
(3,855 Views)
Has this ever worked?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 11
(3,819 Views)
Yes, it used to work. I'm not sure what changed to make it start crashing.
Message 3 of 11
(3,747 Views)
Accepted by topic author Jo-Jo
Have you installed or removed anything? Anything updated? Unexplained system crashes (BSOD)?
Have you tried repairing your LabVIEW installation?
Mike...
LabVIEW Champion
Message 4 of 11
(3,742 Views)
Today I started getting errors related to LabVIEW's temporary back-ups. Also LabVIEW crashed on me once today. Now I think that my installation might just be bad.
I'll try to repair the installation, and let you know how it goes.
Thanks for the help.
Message 5 of 11
(3,739 Views)
I tried to repair LabVIEW, and that failed too.
It looks like it is related to the fact that our IT insists on mapping our My Documents folder to a network location where it gets backed up.
Message 6 of 11
(3,690 Views)
Tell them to stop doing that!
Get them to make My Documents on the c:\ drive again.  Have them create some other network drive to be the folder they backup for you and you take control of copying files into that when you want them backed up.
Short of that, maybe there is a way to get the Icon Editor to work with another directory that is local to your PC rather than the remapped My Documents.  The Icon Editor is a LabVIEW program and you can open it up and modify it if you want.
Message 7 of 11
(3,679 Views)
"Tell them to stop doing that!"
Ha! That is actually my current plan. It is harder than one might imagine, but I think they will finally do it. There are a handful of us here using LabVIEW and other NI tools now, and this seems to cause problems for many if not all of us.
In the mean time, does anyone know of a way to make NI not use My Documents? Is it a configuration I can change, or something?
Message 8 of 11
(3,633 Views)
Try changing the "Default Data Directory" setting under Options>>Paths.
Mike...
LabVIEW Champion
Message 9 of 11
(3,624 Views)
I finally have My Documents mapped locally. I repaired my LabVIEW installation, and now everything seems to be working as advertised.
Message 10 of 11
(3,599 Views)
