INDICATOR / CONTROL NEWBIE QUESTION
Why are there four different images for a boolean ind or control and how can I utilize them?
Message 1 of 9
(2,821 Views)
well, there are 4 states:
- switched off
- switched on
- switching to off
- switching to on
Using system controls you get two more states:
- mouse over switched off
- mouse over switched on
Start reading the LabVIEW help here
Message 2 of 9
(2,813 Views)
Hi Gearimiester,
My name is Jonathan and I work within the Applications Enginering department at NI in the UK,
These images look to be images saved to the clipboard in the customisation of the control/indicator so rather than using a lit up LED you could have a specific image representing the state, Are you wanting to utilise all 4 of the images? Obviously boolean is 1 of 2 states.... True or False so really only 2 states can be used and therefore only 2 representing images.
You could edit 4 boolean indicators to be transparent wehn they are false and use the images to be the true value rather than a colour and then overlay each one on top of the other.
If you let me know what it is you are specifically looking to achieve I would be happy to help.
Cheers
Message 3 of 9
(2,807 Views)
OK - Is there any way to access the other states with a blink property node so as to change the image from on to say switching to off? I was trying to impliment a different png image for the blinking property.
Thanks for the reply!
Message 4 of 9
(2,801 Views)
Jonathan~
Yes they are my custom png files and see reply above for application.
Your solution is workable and I have done it with some other button - indicator applications but I have found that if I do this while the indicators are inside a cluster it really draws on the cpu while idle and slows down the application when running. So I was trying to avoid having to do that if possible.
Message 5 of 9
(2,794 Views)
Accepted by topic author Gearmiester
no, using the Blink property just changes some colors…
When you want free control of the shown image you could use a PictRing instead…
Message 6 of 9
(2,792 Views)
HI,
I guess you could use property nodes to edit the blinking of the LED. I personally edited the Indicator and replaced the standard green block with an image from file.
Ive attached some steps below:
cheers
J
Message 7 of 9
(2,785 Views)
Then i would reccomend teh use of Pictring functions, you may find this article useful:
http://www.ni.com/white-paper/3211/en/
Cheers
J
Message 8 of 9
(2,773 Views)
Thanks for the input guys.
I think I will check out the ring control option and use it as the indicator. now I just need to work out how to control it programmatically.
Message 9 of 9
(2,757 Views)
