11-03-2015 11:13 AM
Hi All,
I'm trying to use the "IMAQ Overlay Multiple Lines 2" in LabVIEW 2014. Apparently, it can use two drawing modes: Fill and Frame. However, when I wire the Drawing Mode terminal with "Fill", I get an error message:
Error -1074395325 occurred at IMAQ Overlay Lines
Possible reason(s):
IMAQ Vision: NI Vision does not support the DrawMode value you supplied.
ANy idea what's going on?
Soheyl
11-04-2015 05:05 PM
Hi SoheyIV,
There's actually a known bug with IMAQ Overlay Multiple Lines 2 that causes the function to throw that error when the fill option is selected; unfortunately, this means that the fill option can't be used at all. If the area you're trying to overlay is a regular shape, you could try using one of the other overlay functions (for example, IMAQ Overlay Rectangle + fill), but unfortunately Overlay Multiple Lines 2 + fill won't work.
04-22-2016 02:12 PM
Thanks Ryan. Does anyone know if this bug is fixed in 2015?
Soheyl
04-25-2016 11:16 AM
Hello SoheyIV,
A corrective action request (CAR) was filed for this bug. This bug is not fixed in LabVIEW 2015. For future reference, the CAR number for this issue is: 364804. To verify is this big is fixed in future releases of LabVIEW, please feel free to refer to the release notes that come along with new versions of LabVIEW. For example, below is a link to the LabVIEW 2015 SP1 Bug Fixes.
LabVIEW 2015 SP1 Bug Fixes:
http://www.ni.com/product-documentation/53045/en/
Best Regards,
j_bou
04-26-2016 07:03 AM
1) I've open the block diagram of IMAQ Overlay Multiple Lines 2,
2) I've copy the call library function with all controls and indicators on my VI
3) I've reconfigured the call library function using the function "LV_OverlayLines2" and works 🙂
If I use the Call Library function with LV_OverlayLines2 in a subVi doesn't work.
Alberto
05-05-2016 03:42 PM
Hi Alberto,
This is interesting. I followed your suggestion, and I switched the call library function from LV_OverlayLines3 to LV_OverlayLines2. It indeed tries to draw the filled shapes, but it seems that it cannot handle the points correctly. The result is a polygon filled with the right color but the shape is completely distorted. Did you apply any other changes too? Did you modify your coordinates or just used the same coordinates?
Soheyl
05-06-2016 01:02 AM
I used an array of points in out from ROI property.
The Points array is a succession of coordinate XY.
Eg. index 0 X0
index 1 Y0
index 2 X1
index 3 Y1
I've trasformed the Points array in array of cluster XY as required in dll (input points).
10-06-2016 03:27 AM
Hello
Is this known bug finding a solution?
(would be nice!)
PF
10-07-2016 02:11 PM
Hi PF,
It looks like the CAR has been originally scheduled to be fixed for 2016 but was unfortunately deferred to an unknown date. It is likely that this may be fixed in the next release in May however it does not have an official fix date currently.
Sam K
12-16-2016 08:34 PM
Could you please post you block diagram to show how you got this to work? I tried to do the same but the shape still does not fill...
