I2C communication NI-845X error -301740
I am attempting to communicate with a Gigoptix HXR5104B 4 channel receiver. I am communicating via the SDA and SCL ports on an NI USB-8451x.
I am attempting to read the device identifier register which is 'E0' in hex. I am receiving error -301740 when trying to communicate that happens during the read-write command.
The communication protocol with this device may be different from what I am currently implementing, however, I am unsure what I am doing wrong. I have attached the protocol and my VI as well as the manual for the HXR5104B.
Thank you.
(3,783 Views)
Do you have a pull up resistor for both your clock and data lines?  That error points to you are missing them.
GCentral
(3,722 Views)
Or not enabling them
"Should be" isn't "Is" -Jay
(3,715 Views)
