08-02-2016 07:31 AM
08-02-2016 02:31 PM
Hi SeanJ,
Because this is an older thread, you'll get more visibility if you post a new thread for your issue. On our forums, newer threads appear higher in the list, so you're more likely to get a response that way.
08-04-2016 08:22 AM
Hi bseguin.
Thanks for your reply.
I have a bit of experience with i2c, (SBC and proprietary software) but not through labVIEW.
I am expecting to specify the address, send a command and get a reply using the FTDI cable. I have 5V pull-ups as the sensor is 5V rated and the cable 3.3V, (I spoke with FTDI and they assured me it should work with the pull-ups).
I'm not sure what you mean by the 'the address and base address'. What is the difference between them?
Also, what is the correct mask? By this do you mean what I would call the command?
Seán
08-04-2016 08:23 AM - edited 08-04-2016 08:23 AM
duplicate...
08-06-2016 08:09 AM
08-08-2016 10:51 AM
Hi bseguin,
There's no setup of any significance.
I have a TE 4525DO-DS5AI015DP pressure sensor. I supply 5V from a tracopower 5V supply and have two 4.7k pullups resistors connecting SDA --> 5V and SCL --> 5V.
I try to talk to it using the FTDI 3.3V I2C device which is also connected to the 5V pullups, (this is fine according to FTDI).
Rgds,
Seán
08-09-2016 05:38 AM
I did a quick schematic of the implementation.
08-09-2016 07:30 AM
According to the manufacturer datasheet, the base address for your package in I2C interface is I = I2C (Addr.0x28H)
So to access the device, be sure you use the address 28 in hex format.
Benoit
08-09-2016 10:53 AM
Hi Benoit,
I posted my question in a new thread. It references your code.
I added some traces to show that I transmit 0x28 and 0x51.
01-04-2017 01:55 AM - edited 01-04-2017 01:58 AM
