I would like to know the real-time image converted to a speckle image.
I am using a usb ccd camera, I'd like image processing or converting the image to get the image obtained speckle image.
LabVIEW versions are writing in 2013.
The first usb ccd camera thorlabs's DCU223C 1024 x 768 camera and
Use the 'uc480_LiveStream_32bit_Vision' in the current LabVIEW template was able to see an image that looks as ccd cameras in real time.
Since the real-time image looks like to be able to see a switch to the speckle image.
I wonder how or whether to create a program to create a sub--vi.
Help
(2,670 Views)
Sorry if I'm not answering your question, but the IMAQ NthOrder filter can remove speckle noise. Do you just want to look at speckle noise? You may be able to accomplish this by running a diff on the original image with the filtered image, which would in a sense be just the noise. But it would be all kinds of noise, not jsut speckle noise specifically.
Again, if you could clarify a bit, it would be helpful to us in answering your question more fully.
(2,616 Views)
