08-28-2010 05:48 AM
Dear Sir,
I am a Ph.d student from National University of Singapore. I just started to learn about Labview for my new project. Could you please send me the VI that you posted here. It is extremely relevant to what i am doing.
Many thanks.
Kelvin
04-14-2011 12:53 PM
I have a similar question to what Mr. Smith asked on this post. I am trying to continuosly read an lvm file of recorded data that was recorded by connecting a DAQ assistant block with the following settings:
Acquisition Mode-Continuous Samples
Samples to Read-1k
Rate(Hz)-10k
I then connected the output of the DAQ to the "Write to Measurement File" block.
Now I am trying to use the "Read From Measurement File" block and feed the file data through a "Spectral Measurements" block and ultimately display the output on a Waveform Graph.
The problem of how I currently have my VI setup is that the data displays on the Waveform Graph much more rapidly than when I was recording the data to the file. I know this because I had the signal from the DAQ connected to a Waveform Graph then as well.
I tried implementing the solution posted by for(imstuck) on 11-09-2009 12:51pm but was caught up with converting the data output of a "Spectral Measurements" block to agree with the input required by a "Append Waveforms" block. I have attached that VI, it will not run at the moment because of this problem.
I have also attached my VI that reads through the file rapidly, along with the lvm file that I am reading.
If someone could take a look I'd appreciate it.
Thank you
I had to change the lvm suffix to .txt to attach it so I'm not sure if it will still work when reading it from a VI or whether the extension will have to be changed back to .lvm
04-17-2014 11:44 PM
I'm doing project about EMG signal processing, I used read from measurement file to read EMG signal file. I want when i choose the file the file is immediately read off and display on the waveform graph and replace the old file read. I don't know how to implement it. I have read the above discussion but I could not find how to do it, so I look forward to help. This is my program file. Thanks for so much.
P/s: I using LabVIEW 2013.
04-18-2014 06:30 AM
Your Read File should be INSIDE of the loop. You currently have it just reading once before the loop even starts.
04-18-2014 10:18 AM
The way of read file in side of the while loop is impossible because programs such will fail.
04-18-2014 10:25 AM
04-25-2014 05:59 AM
Thanks for your answer.
The problem is that I want while the program is running, when I choose to read a new data file, the file is done immediately read and displayed on the graph.
I need a solution for my project.
Thanks for so much.
04-25-2014 07:26 AM
Sounds like you want to use an Event Structure. Create a case for File->Value Change. Inside of that case, do your analysis and update your graphs. You will also want a Stop->Value Change event case to handle pressing of your stop button and stopping the loop.
