Reply
I want to evaluate a formula which has complex numbers please help me????
I'm a begineer in labview. I want to evaluate an equation which has complex numbers through text code.. Any suggestions Please????
for(f=0;f<=2560;f=f+0.3125)
     R=((H12-e^(-i*k))/(e^(i*k)-H12))*e^(i*k);
where H12 is 1d array of complex number
            i         square root of -1
            k         function of frequency
            f          frequency
(564 Views)
Re: I want to evaluate a formula which has complex numbers please help me????
Just use a For-loop in combination with a 1d-array of complex numbers. The following example shows the usage of a array of complex numbers:
https://decibel.ni.com/content/docs/DOC-28831
Or is there any other problem?
Michael
(552 Views)
Hi!
You could try using a script node (http://zone.ni.com/reference/en-XX/help/371361H-01/lvconcepts/scriptnodes/) if you have MATLAB installed on your PC.
Or you can implement it in Labview, since there is a Complex data type (actually more than one).
Here's a snippet as a draft/starting point:
(550 Views)
Would you know how to do this if they weren't complex numbers?  If so, then all you have to do is change the numberic representation to a complex data type.
The discussions from the Advanced User Track is not over. Join in the conversation: 2016 Advanced Users Track
(548 Views)
Are you saying you don't want to use LabVIEW to evaluate this? In which case I suggest asking on a different forum.
There is no 'f' in the loop, I don't understand what the loop would evaluate, unless k is a constant in which case the loop is redundant.
            f          frequency
If k is a function of frequency you need to say what that function is. For example if you are evaluating 'k' for changing 'f' and applying it to the equation for R. I don't know what the best procedure would be but my first port of call would be nested loops: 'R' for each 'k' for each 'f' ?
In the absence of a function for k this vi would evaluate you formula for k=f, I don't know if this wil help any.
(518 Views)
Thank you Marco Mauri & Michael for your sugesstions..
I have implemented it by using loop as you said, but it looks little bit messy, and it becomes difficult to debug,
So, script node will be  a better choice. since in my program there are many such equations.
I don't have matlab installed in my PC, but i have scilab installed can i use it, If possible i want to know the syntax...
Thanks and Regards,
Giridhar
(486 Views)
Hi girikavali,
- when the VI looks messy you should clean it up (there even is the automatic cleanup tool...)
- What means "difficult to debug"? A script node / formula node / scilab node is even more difficult to debug...
CLAD, using 2009SP1 + LV2011SP1 + LV2017 on Win7+cRIO
Kudos are welcome Smiley Wink
(469 Views)
