03-10-2012 04:18 PM
I want the Programming pallet to appear whenever I right-click while in the block diagram. Right now I have to look at the Express dialog, arrow down and then click on Programming. I want Programming to pop up first. This has to be dirt simple but for some reason I'm not seeing the solution in Help.
Solved! Go to Solution.
03-10-2012 04:42 PM
go to tools...options...controls/functions palette...formatting
Select "Icons only" and "category(standard)".
Now right-click and pin the palette to get to the "customize" button. Select "Change visible palettes..." and click "select all".
see if this is better.
03-10-2012 04:43 PM
In LV 2010:
Right-Click on the block diagram to get pallete.
Click on "Search" button.
Click on "Return" button.
You should now be in a mode where you can make changes.
03-10-2012 04:59 PM
This worked, thanks.
03-10-2012 05:00 PM
This worked as well. Thanks.
