11-24-2006 12:17 AM
11-28-2006 10:55 PM
Hi Ankit,
Please refer to the following KB to see which targets are supported by LabVIEW DSP.
http://digital.ni.com/public.nsf/websearch/AF9886D62684C05D86257101007F4647?OpenDocument
A USB cable is used to connect to those boards so that the user can download the code to the embedded target. Currently, the LabVIEW DSP Module does not support custom DSP hardware even if the hardware has similar or identical peripherals to the supported targets.
Hope that helps!
