11-17-2009 02:28 PM
I've got the labview vi written to read my IMU data from a serial port in COM1 and it displays onto the table on the front panel. I'm having trouble getting this data onto an excel spreadsheet. Any ideas? Right now my data will collect one reading instead of continuously reading my IMU which displays data in a continuous stream.
11-17-2009 09:35 PM
Hi
Your vi is in 2009 version, which i am unable to open in 8.6
However, if you want your data to be saved in excel sheet, here is the VI
09-09-2015 05:34 AM
i have alrady wright data on sd card that is the imu data. now i want to read this file (data) offline can any one suggest some vi for the data readind of the imu in labview. using this i can observe all the data of imu for the dynamic behaviour of any object...
Ankesh...
09-10-2015 10:06 AM
Hi Ankesh.
I'm not sure exactly what your set-up is or what your application is about, but I found an article that may be helpful. It explains how to configure and read IMU data in LabVIEW.
http://www.ni.com/white-paper/8163/en/
Also, you might want to open a new forum post to get more activity. Due to this forum's age, it may not get as much visibility.
Hope this helps!
Casey L.
