I installed v 7.0, and then tried to run an example DAQmx VI from the developer zone. However, the VI can not start because a lot of DAQmx VIs seem to be missing. Doing a search on my Labview 7.0 directory, I do not find any VIs starting with DAQmx*.vi.
Furthermore, choosing Functions|input, I do not see the DAQ assistant (I think that is what it is supposed to be called?)
p.s. I am using the Prof devel system version/
