12-05-2013 08:32 AM
Hi ,
I have faced problem in writting to measurement File. I have received an error state (( These cannot be wired together because their data types (numeric, string, array, cluster, etc.) do not match. Show the Context Help window to see what data type is required.
The type of the source is cluster of 3 elements.
The type of the sink is Dynamic Data.))
How I slove this problem?
I have attached the labview file. i would be so grateful if you help to figure out the problem.
Khalid
Solved! Go to Solution.
12-05-2013 08:45 AM
12-05-2013 08:52 AM
Hi udka,
Thank you so much for youe replay.
I have saved the file as you requsted.
Khalid
12-05-2013 09:02 AM
Hi engkhalid,
-Yes, the Output of FFT-(RMS) is a cluster of three elements, which will not be accepted by Write to Measurement File.
-May be you can try Unbundling the cluster and build the array and then send the data, But this will alter how the data is saved in the file i guess.
-Please find the attachment for the modification i suggested.
12-05-2013 10:35 AM
Hi udka,
Thank you so much for your help. Actually, there ia an error appeared while i am running the code as can be shown in attached file
Khalid
12-05-2013 10:38 AM
12-05-2013 10:44 AM
You should select proper reply as solution. And i guess it's my second post is the solution, not the third.
12-05-2013 10:52 AM
Hi udka,
I am so sorry. I am not familiar with this fourm but relay it is helpfull. However, you didn't told me how I should solve the next problem. I need this code to do open loop control system.
Khalid
