I need a digital control unit expert (DCU)
Hi, I need help with my Digital control unit wich is connected to a sensorDAQ card.
In my proyect I use 2 sensorDAQ cards, but only in one of them is connected the DCU, i run a program in wich i change the chanel of the digital control unit with a case structure, so if is true, then the ch of the DCU is changed to #14 for a set amount of time and then it must stop and dont turn on again, if it false it must leave the DCU in #ch 0.
My problem is that whenever it get any case (true or false) a window pop up and ask me in wich card is the DCU connected, this is the window I whant to avoid.
I find in the vernier digital instruments in the part of low level programing 2 modules, start and setup, I almost sure with this modules I can select that always run with a card.
So can it be done? If yes in wich way, if no, can you tell me why and help me find anotehr solution?
Thanks for your help.
(2,329 Views)
I'd like to ask you what is the DCU that you have, is it National Instruments hardware?
Best Regards
Miguel Fonseca
http://www.ni.com/support
(2,294 Views)
Is vernier hardware. Is this one. http://www.vernier.com/products/sensors/dcu-btd/
(2,288 Views)
Can you please attach an image with an screenshot of the window that you want to remove?
Miguel Fonseca
(2,267 Views)
