01-17-2012 09:32 PM
LabVIEW TDMS File Viewer does support zooming in and out, and export graph data to images. I have a couple of questions:
1. Do you not want to launch the LabVIEW Development Environment at all? If not, why not? Are you viewing them on a machine that doesn't have it? Would a LabVIEW-built EXE be ok?
2. Do you think the TDMS API is insufficient, or that the existing LabVIEW TDMS File Viewer is insufficient?
3. If you think LabVIEW TDMS File VIewer is insufficient, whether there are other things that are preventing it from being useful for you?
Thank you.
01-17-2012 09:37 PM - edited 01-17-2012 09:37 PM
as ben said
"Mwahahaha."
Kinda sounds like Bowser in mario party.
Sometimes a coping saw can do the same job a lumber mill can- it will take more time
sometimes a sledgehammer can do the same job as an ice pick- it may be messy
DIAdem is a tool- just like sledgehammers and coping saws-
"Watch where you put your fingers"- St Joseph (the carpenter)
01-17-2012 09:39 PM
I am not a labview programmer and My guys just used a NIDAQ to record of waveforms in TDMS on the field that needs to be viewed.
I just need a viewer to view the stored waveforms in simple layman's user interface.
I do not want to get into the details of programming labview to view the waveforms.
I just need a viewer that allows a non-labview programmer like me view waveforms, simple zoom in/out , stagger the waveforms.
01-17-2012 09:57 PM - edited 01-17-2012 10:04 PM
I'm sorry.
I did not mean to offend. TDMS is a relativly new and exciting file format. But, as such lacks some advanced interperater features. Especially when trying to zoom/offset with programs predating its introduction. DIAdem may be your best COTS choice for this but I am not on the cutting edge of file formats.
Again, no harm intended- BUT,
"I need one" means to me, "I must find one, or CREATE one or, go without and find another ...." Reevaluate your need- It may be able to be solved without new intelectual property
01-17-2012 10:43 PM
Yes. I guess i have to make do with diadem for the time being.
It may be a powerful program but if it is user UNfriendly, it will not go far.
For the NI developers, start your creative engines.
01-18-2012 11:49 AM
Hello KNA,
We have some ideas for improving the existing TDMS File Viewer VI, but it's not clear to me if you have tried it and not liked it, or if you didn't even find it. If the former, we would like specific feedback on what you didn't like, since the two specific things you've mentioned so far (zoom, export) are supported, as Simon and Yongqing mentioned. You can find it here:
[LabVIEW Install Directory]\vi.lib\Utility\tdmsutil.llb\TDMS - File Viewer.vi
i.e. C:\Program Files\National Instruments\LabVIEW 2011\vi.lib\Utility\tdmsutil.llb\TDMS - File Viewer.vi
or in the palettes:
Programming - File I/O - TDM Streaming - TDMS File Viewer
Now if your need is to view TDMS files on a different machine where LabVIEW isn't installed, that's another issue entirely, but I would like to prioritize the specific problems that customers are having, so the more specific you can be with your feedback, the better we can help you.
Jeff
01-18-2012 12:04 PM
Jeff
(Did you guys lose the style guide??????):smileysurprised:
01-18-2012 12:48 PM - edited 01-18-2012 12:51 PM
@Jeff Bohrer wrote:
Jeff
- clean-up the BD- save it on monitor 1 and not maximized
- remove unused code (error tunnel out of event lower Left ???
- Re- layout the con pane for Loadanformatvalues.vi so it can be viewed as an icon
- add vi documentation and include it in the help file
The last time I saw feedback about an NI VI it was "fixed" by putting a password on the diagram. Hopefully they will do better this time.
And when last I looked...
It would go nuts if you resized parts of the GUI too far (can't remember the details).
There was also another issue where it would not refresh properly when rerun using a different data set.... ?
Ben
08-01-2013 08:11 AM
I just came across this forum, and I thought I would suggest a new product that was just released on the LabVIEW Tools Network, Scout TDMS Editor. Check it out here:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/211879
Rob
08-01-2013 10:14 AM
That isn't half bad actually.
There are a few minor things I don't like, but it's worlds better than the NI Viewer. I can finally select multiple signals to graph from channels in different groups. There is basic filtering, a good set of plot controls with cursors, and multiple Y axis, and settings on how to load the data similar to the NI solution but it can ask how much data you want to load when you open the file. The UI is good but not reat. There are several controls that look like they don't match the whole look but still works fine.
It doesn't appear to be free because I have a 30 day trial and it is unclear how much it costs. I couldn't find the product on their website either.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
