12-18-2015 08:25 AM
@MarcoMauri wrote:
Hi!
Try this one.
I'm capturing the mouse click and creating on the fly a rectangular ROI of a given size.
Marco
p.s. change the X and Y size of a ROI to a value different from 0... I forgot to update the default value.
Hi Marco,
Thanks a lot. It is working very well. I able to code with help of your reference vi attached in your post.
NOw I am facing another problem -
"Error -1074396154 occurred at IMAQ WritePNGFile
Possible reason(s):
IMAQ Vision: The image is not large enough for the operation."
Even after cropping a 100X100 ROI I am getting this message from a IMAQ Write File 2 vi. It has been used to save the cropped ROI.
I am trying hard to fix it.
I shall be thankful if anyone can pu some light on it.
Thanks.
12-18-2015 09:24 AM
Hi sukhiray, please attach your code which is generating the error. I tried to save mine for 2012, let's see if it works:
12-19-2015 01:04 AM
Thanks gregoryj for your support. These are openable.
Now the previous problem has been solved. Presently I am getting trouble in saving the cropped ROI. See the attached code, The last vi to save image is returning error. I have attached the code and error snapshot.
I shall be thankful if you can help me to findout the problems or mistake in my codes.
Thanks again for your active participation.
12-19-2015 03:50 AM - edited 12-19-2015 03:55 AM
I use another method with more flexibility test this vi too
12-21-2015 01:15 AM
Thanks Hatef.
It is also working good but it is adding fill color which is not required.
Till thank you very much for your support.
12-21-2015 02:40 AM
there is the control in vi that you can select three method for roi
frame
highlight
and fill
chnge fill to frame for not filling
12-22-2015 12:36 AM
HI all, Thanks for your support.
My code is runnign well with floating ROI of user defined size.
Now I am getting an odd problem with IMAQ readfile vi. Sometimes it is working really good but next day it is showing error like -
Error -1074395995 occurred at IMAQ ReadFile
Possible reason(s): IMAQ Vision: File not found.
I am really confused. Can anyone help me to understand this?
12-22-2015 01:15 AM
12-23-2015 04:14 AM
VI can't be uploaded as it is part of a big program and extracting that part will includes a huge hazzard.
I have solved this problem by designing my own VI for the same.
