12-16-2015 06:23 AM
I am working on image processing. In my present work I need to crop ROIs from images but the size of ROI should be same for all. So I have to fixed the dimension of ROI through block diagram coding so that all the cropped ROI finally will be of same size.
I able to find a way to create a ROI of a given size, movable on the image using Convert Rectangle to ROI vi. But the rectangle is till resizable. Is there anyway to fixed the size?
Please help me out.
12-16-2015 10:50 AM
You can check ROI size after it has been moved (check image event mouse up) and discard size changes.
Or
You can track position of user specified ROI-point and overlay rectangle on image to show user the resulting processing ROI. There is a little confusion: ROI on the image display is only user interface and ROI as region of interest for processing.
12-17-2015 09:27 AM
Or
Thanks for your support and response.
Please see the attached image file. How to reset the rectangle size if anyway altered by user?
I am also not getting any way to find the ROI-point, can you please help me?
12-17-2015 09:43 AM
Please attach the VI, not a picture.
If the size is really critical, I would make the user set the width, height, and left and top offset using numeric controls.
12-17-2015 10:37 AM
pleasesee the attachment... my requirement is keeping the ROI size fixed, not the image size is my concern.
12-17-2015 11:03 AM
You can do something like this, run ROIsample.vi. You do have to have an ROI drawn already, but this was something I was specifically asked for by one of my users.
12-17-2015 11:12 AM
You could allow users to define only point ROI and draw the fixed size rectangle as an overlay.
It will up to you to translate the point to a rectanglurar ROI whenever needed.
Marco
12-17-2015 09:30 PM
Thanks gregoryj. As I am using labview 2012 can't open your files. Can you please save them in compatible mode and re-share?
Thanks for your support.
12-17-2015 09:31 PM
Marco
Thanks Marco, but I can't extract mouse information fron that vi I am using. Can you help in that?
12-18-2015 01:21 AM - edited 12-18-2015 01:25 AM
Hi!
Try this one.
I'm capturing the mouse click and creating on the fly a rectangular ROI of a given size.
Marco
p.s. change the X and Y size of a ROI to a value different from 0... I forgot to update the default value.
