I'm having problems with the hp8753 network analyzer vi.
this vi is taken from the hp8753e network analyzer driver. The save function works but the recall function does not.
(2,968 Views)
which VI do you mean?
(2,968 Views)
fprintf(nwa,'CLES;ESE 1;SRE 96;OPC;SAVC;');
fprintf(nwa, 'ESE0;SRE 0;');
fprintf(nwa, 'HOLD');
To recall the error coefficients back to the network analyzer You have to write the above code lines in MATLAB after reading  all the error term coefficients. Thanks. Hope this will help You.
Best Regards
KHAN
(2,207 Views)
Explain doesn't work, does it generate an error? If so what the error says? How do you use this vi? Are you sure you are recalling the register that was saved? Did you let enough time to the analyzer to save/recall the settings before using them?
If you have a vi that shows how you use the recall function attach it.
(2,203 Views)
