09-01-2009 01:46 PM
I have a DAQ Assistant configured to read 2 channels at the same time. When I wire a graph indicator to the output, I see the 2 signals jumbled together. How do I split them up into seperate signals?
When I wire any type of indicator it is showing just one output of a single channel.
I want 2 indicators showing 2 different signals as expected from the 2 channels configured. How to do this?
I have tried using split signal but it end up showing only 1 output from 1 signal in both the indicators.
thanks in advance.
09-01-2009 01:59 PM
09-01-2009 02:05 PM
Yes you are right. I tried that but I did not get the result.
I just found the way. When we launch split signal, we should expand it (split signal icon) from above and not from below. It took me a while to figure out this.
thanks
03-26-2014 11:54 AM
Thanks for the post, We need to use the Split Signal subVI and then you can take multiple outputs from a DAQ Assistant subVI.
03-26-2014 02:17 PM
Thank you, Gangadeep. I got it.
Hareesh Gottipati
