03-15-2006 10:06 AM
03-16-2006 02:39 PM
Have you tested and confirmed that the communications to the device is working using the MAX (Measurement & Automation Explorer) utility?
LabVIEW will not work if you have not gotten it setup and working first in MAX. You should at least be able to do a device ID query successfully.
FWIW, here is another thread about communicating with a SR lockin amp.
11-08-2013 05:41 PM
I am facing very similar problem. Can not communicate with SR510.
I am trying with MAX also but SR510 is not responding. I have got two same models of SR510 and none of them is responding.
I am using GPIB-USB-B to connect the lock-in to computer. This is strange as I have already programmed several lockin SR530 and SR830 as well as SR760 for other eperiments. This is the first time that I am facing such a problem. Strangely, on scanning for GPIB instruments in MAX, it finds the lock in and also autometically detects the GPIB address which is 23. I also changed the GPIB address in the lock in and MAX detects the address correctly but on communicating with the instrument (in MAX as well as in LabVIEW) the instrument does not respond and shows the time out error in GPIB read. I have checked the command syntax and it is correct including end-of-string characters. Any guess what can go wrong???
