I have a problem with my setup. My labview project has been running perfectly till today, when I cannot compile any project. My project works perfectly in another computer. Same with "simpler" projects that I have. I cannot compile. I have tried to compile an empty vi, but the problem is the same.
I decided to remove all labview components from my host computer. I removed everything from the host (NI-MAX/my-computer/sofware, all programs selected) and reinstalled Labview 2013. After doing that, the problem still happens. Attached you have a picture where you can check which error appears. It even happens with empty fpga VI.
I am running Labview 2013 in an Windows 7 64bit. Xilinx 14.4 13.0.0
My software package worked perfectly till today. Maybe something got corrupted...
Any suggestion? Thanks in advance
Pablo
