12-16-2014 12:05 AM
I tried to unbundle this Edge coorinates. But not able to fnd solution . i have attached my vi file
12-16-2014 03:44 AM
You are working with 1D arrays of clusters. You need to use e.g. "Index Array" to obtain one cluster from the array before you can unbundle it to find the edge-to-edge distance.
12-16-2014 03:50 AM
thanks a lot 🙂
12-16-2014 03:52 AM
if you have found a solution that works for you, please mark this topic as solved 🙂
12-16-2014 03:59 AM
hi JarleEkanger,
1. right now i am going to work in the die correction project. do you any vi files related to that.
2. And i need to create .CSV to read and write operation like database (memory) . do u have any vi related to that.
12-16-2014 06:09 AM - edited 12-16-2014 06:09 AM
Hi saran,
1. Can you explain "die correction project" before even asking for help on this topic?
2. LabVIEW comes with ready-made functions to handle CSV files (Read/WriteSpreadsheetFile). And you should stick with your older thread for that topic! Don't create double posts!
12-16-2014 09:06 AM
12-16-2014 09:13 AM
Hi saran,
you don't modify inbuilt functions. NEVER!
With CSV files you need to read and save the whole file, when you want to access a particular "cell" in the data.
CSV files are simple text files, they don't provide special access methods like Excel does…
So read your file, change the array element you want to change and save the file!
12-16-2014 09:20 AM
12-16-2014 09:21 AM
