02-14-2006 12:36 AM
02-14-2006 12:53 AM
02-14-2006 03:02 AM
02-15-2006 02:11 AM
02-15-2006 02:50 AM
12-14-2006 06:48 AM
12-14-2006 09:06 AM
12-15-2006 02:44 AM
12-15-2006 08:16 AM
I can't look at your VIs because I don't have 8.2. You write to the sensor the same way you write with Hyperterminal except you have to provide the termination character(s) in the program you write. Assuming that Basic Serial Write and Read is still one of the shipping examples in 8.2, look at the command being sent and the \r\n that is at the end of the string being written. A \r is a carriage return and a \n is a line feed character. Many instrument require one or the other, or both. In order to send it correctly, your string control or constant must be set to '\' Code Display by right clicking on the control/constant.
If you have the termination done correctly, maybe someone with 8.2 can look at your code. Or you can post an image of the block diagram.
12-15-2006 09:28 AM
